Hi,
Everything seemed to be ok - thanks to the great disk upgrade guide - with my 500GB SATA drive (meaning that music was played!), until I noticed the player storage is "only" 128GB.
So I decided to start over, and now I'm stuck on "Pumping partition".
I tried the going over the disk upgrade guide with MLord's
v515 hijack,
big disk builder v6 together with
car2_v3a11_hijack,
car2_v2.01_hijack or
car2-developer-v3.00-alpha11 images, but I keep getting stuck on the "pumping partition" stage. I also followed the two-stage
"Partitioning/Formatting an empeg's Hardisk Manually" guide, which went good until to the point I needed to "install the player's image" (how?).
I realize that 500GB SATA HD + IDE-to-SATA converter means a long shot, buy (a) it
did work the first time (only with the 128GB limit) and (b) I did check the drive with and without the converter on my PC (that's how I partitioned/formatted it manually) and the hardware seems to be ok.
Any ideas?
Thanks,
Ury
